Multifunction DAQ
NI-DAQmx 19.0 does not install the correct 64-bits NIDAQmx.lib file!
Hi. I've just installed the latest version of NI-DAQmx (v19), and got a LNK4272 error while trying to build a 64-bit C application using MSVC.
The cause of the error is that the "NIDAQmx.lib" file installed in the "C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc" folder is the same as that found in the "lib32" folder (both md5 checksums are identical).
Is there any other place where I can get the 64-bit version, or I should downgrade to v18 until the problem is solved?
(2,932 Views)
I've got the same problem.
Have you got an answer?
Best regards
(2,822 Views)
No answer yet. I just downgraded to 18.6 and everything works fine so far.
Guess we'll have to wait for 19.1 patch release.
Regards.
(2,809 Views)
Accepted by topic author LeDrull
If you are interested, I worked around by recreating the .lib file.
  • Download the attached .7z file and unpack the .def file.
  • In Visual Studio, click on Tools>Visual Studio X64 command prompt
  • Type this command line : lib /def:nidaqmx.def /machine:X64 /out:nidaqmx.lib
That's all!
Hope this can help.
Best regards
Ludovic
(2,807 Views)
Thanks, now everything works as expected!
I didn't realize the LIB file could be recreated from the DLL...
(2,779 Views)
Hi all,
This was a defect in NI-DAQmx 19.0; the installer was installing the 32-bit nidaqmx.lib to both the 32-bit and 64-bit locations. This has been corrected in NI-DAQmx 19.1.
If you can't upgrade, the workaround that @Ludovic posted above for generating a replacement nidaqmx.lib will also work.
Brandon Streiff
ni.com/compactdaq · ni.com/daq
(2,630 Views)
