05-20-2019 02:58 AM
Hi. I've just installed the latest version of NI-DAQmx (v19), and got a LNK4272 error while trying to build a 64-bit C application using MSVC.
The cause of the error is that the "NIDAQmx.lib" file installed in the "C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc" folder is the same as that found in the "lib32" folder (both md5 checksums are identical).
Is there any other place where I can get the 64-bit version, or I should downgrade to v18 until the problem is solved?
06-03-2019 03:50 AM
I've got the same problem.
Have you got an answer?
Best regards
06-04-2019 12:51 AM
No answer yet. I just downgraded to 18.6 and everything works fine so far.
Guess we'll have to wait for 19.1 patch release.
Regards.
06-04-2019 02:21 AM
If you are interested, I worked around by recreating the .lib file.
That's all!
Hope this can help.
Best regards
Ludovic
06-05-2019 04:45 AM
Thanks, now everything works as expected!
I didn't realize the LIB file could be recreated from the DLL...
07-12-2019 02:11 PM
Hi all,
This was a defect in NI-DAQmx 19.0; the installer was installing the 32-bit nidaqmx.lib to both the 32-bit and 64-bit locations. This has been corrected in NI-DAQmx 19.1.
If you can't upgrade, the workaround that @Ludovic posted above for generating a replacement nidaqmx.lib will also work.
