NI-DAQmx 19.0 does not install the correct 64-bits NIDAQmx.lib file!
Hi. I've just installed the latest version of NI-DAQmx (v19), and got a LNK4272 error while trying to build a 64-bit C application using MSVC.
The cause of the error is that the "NIDAQmx.lib" file installed in the "C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\lib64\msvc" folder is the same as that found in the "lib32" folder (both md5 checksums are identical).
Is there any other place where I can get the 64-bit version, or I should downgrade to v18 until the problem is solved?
(2,937 Views)
I've got the same problem.
Have you got an answer?
Best regards
(2,827 Views)
No answer yet. I just downgraded to 18.6 and everything works fine so far.
Guess we'll have to wait for 19.1 patch release.
Regards.
(2,814 Views)
Accepted by LeDrull
If you are interested, I worked around by recreating the .lib file.
  • Download the attached .7z file and unpack the .def file.
  • In Visual Studio, click on Tools>Visual Studio X64 command prompt
  • Type this command line : lib /def:nidaqmx.def /machine:X64 /out:nidaqmx.lib
That's all!
Hope this can help.
Best regards
Ludovic
(2,812 Views)
Thanks, now everything works as expected!
I didn't realize the LIB file could be recreated from the DLL...
(2,784 Views)
Hi all,
This was a defect in NI-DAQmx 19.0; the installer was installing the 32-bit nidaqmx.lib to both the 32-bit and 64-bit locations. This has been corrected in NI-DAQmx 19.1.
If you can't upgrade, the workaround that @Ludovic posted above for generating a replacement nidaqmx.lib will also work.
Brandon Streiff
ni.com/compactdaq · ni.com/daq
(2,635 Views)
