Multifunction DAQ
NI-DAQmX Hardware Synchronization for 2 module NI-9223 !!!
Dear All
I am using NI-cDAQ 9184 and 2 Module NI-9223(1M) to acquire 6 channels analog input from Acoustic Emission sensors(frequency from 20kHz-400kHz) with external signal conditioning.
Please kindly do let me know how to synchronize using NI-DAQmX? Does NI-9223 support hardware synchronization?
Thanks and Regards
Luong.Tran
(4,532 Views)
Accepted by topic author Luong.Tran
Hi QuanLuong.Tran,
here http://www.ni.com/white-paper/4322/en/ you can find how to trigger and synchronize different channels. It should work.
CaravagGIO
(4,500 Views)
Just put both devices in the same task, DAQmx will configure the hardware synchronization for you:
Best Regards,
John Passiak
(4,475 Views)
Thanh you so much for your information1
Best Regards
Luong.Tran
(4,404 Views)
