Multifunction DAQ
NI-DAQ drivers don't work when upgrading to LabVIEW 8.2 from 7.1
I am working on upgrading our LabVIEW software from 7.1 to 8.2. I installed 8.2 and it works. However, when I load this specific VI, I get multiple errors. The errors come from the NI-DAQ VI's that it uses. I get the error "Code cannot be generated correctly for this VI". Is there something I need to do in order for the NI-DAQ VI's to run with 8.2?
(3,155 Views)
What version of DAQ or DAQmx are you using? It should show up in MAX under software, click on it to get the version info on the right pane of the window
(3,145 Views)
I installed the DAQMX software version 8.0.1
(3,141 Views)
Can you post the vi in question?
Current rev of DAQmx is at 8.3.
Did you uninstall all of LV7.1 before installing 8.2?
I wonder if that vi uses tradional DAQ and now you have DAQmx installed
(3,132 Views)
All the VI's are not working.
I did not unistall LabVIEW 7.1
I think the vi is using traditional DAQ.
(3,125 Views)
That may be the culprit- running vi's based on traditional DAQ with DAQmx installed.
I am unfamiliar with DAQmx 8.0.1, it was not listed on the DAQ info page
http://digital.ni.com/public.nsf/websearch/97D574BB1D1EEC918625708100596848?OpenDocument
You may have to revert back to traditional DAQ v7.4.1. I "think'" the install of 8.2 has the option to install traditional DAQ, not sure.
That's about the end of my knowledge here, can anyone else assist?
How's the weather in Tucson, I presume. I'm just up I-10 a ways, W of Phoenix.
(3,118 Views)
That was it. The VI will not work with the DAQmx VIs.
Thanks for your help. The weather is great here in Tucson, a little cool in the morning.
(3,110 Views)
