11-02-2006 02:37 PM
I am working on upgrading our LabVIEW software from 7.1 to 8.2. I installed 8.2 and it works. However, when I load this specific VI, I get multiple errors. The errors come from the NI-DAQ VI's that it uses. I get the error "Code cannot be generated correctly for this VI". Is there something I need to do in order for the NI-DAQ VI's to run with 8.2?
11-02-2006 03:01 PM
11-02-2006 03:26 PM
11-02-2006 03:37 PM
Can you post the vi in question?
Current rev of DAQmx is at 8.3.
Did you uninstall all of LV7.1 before installing 8.2?
I wonder if that vi uses tradional DAQ and now you have DAQmx installed
11-02-2006 04:00 PM
11-02-2006 04:27 PM
That may be the culprit- running vi's based on traditional DAQ with DAQmx installed.
I am unfamiliar with DAQmx 8.0.1, it was not listed on the DAQ info page
http://digital.ni.com/public.nsf/websearch/97D574BB1D1EEC918625708100596848?OpenDocument
You may have to revert back to traditional DAQ v7.4.1. I "think'" the install of 8.2 has the option to install traditional DAQ, not sure.
That's about the end of my knowledge here, can anyone else assist?
How's the weather in Tucson, I presume. I'm just up I-10 a ways, W of Phoenix.
