02-22-2010 07:10 AM
Hello all,
I'm hoping someone could enlighten me as to the root cause of the error I'm getting. I only purchased this DAQ card and after completing the installation, conencted the DAQ card. I opened up NI Max and the DAQ card was present under My System>>Devices and Interfaces>>NI-DAQmx Devices. When I attempted a Self test the above errror was returned??? I'm hoping it's something simple that I missed and with fingers crossed, someone with more experience than myself of NI devices could help!!!
Thanks in advance,
Paul.
02-22-2010 01:30 PM
Hello Paul,
This error code points to a missing component from the driver. Please try repairing the DAQmx installation from Add/Remove Programs » National Instruments Software » NI-DAQmx.
Hope this helps,
02-24-2010 04:42 AM
Thanks Seth for your advice. I uninstalled and re-installed the DAQmx software...but still no joy! I tried it on a friends PC and the card is working perfect??? Would you or anyone have any suggestions as to a setting that might be causing this issue on my PC? Do I need to disable a setting that is causing a blocked reading?
Thanks in advance,
Paul - Slowly, having a nervous breakdown 🙂
02-24-2010 02:42 PM
Hmmm, I'm surprised that the uninstall and reinstall did not fix the issue. Do you have any other NI software installed? It's possible the damaged component is one that other NI software also uses and the installer didn't detect that it was damaged. If you do have other NI software, would you be able to reinstall it as well? If so, try this utility from Microsoft and use it to remove any references to NI software, then reinstall the software.
Good luck!
02-26-2010 03:02 AM
