Hi everyone, I am new here as such, I have no idea on what location to select for this topic. Please pardon me.
I am a student and I just started reading up more on the NI DAQ USB-6002 device. The question I have is, does the DAQ device work the same as an Arduino board whereby once a code is uploaded into the device, it just requires a power source to function?
In short, no. The code would need to run on a more-or-less "normal" PC that remains attached to the USB-6002 via USB. DAQmx makes the USB connection pretty transparent though, so you generally don't need to deal with USB explicitly in your programming.
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
I am new in using NI daq 6002 and trying to measure voltage variations in a cell membrane. Briefly, I need to collect all data points and plot it in a linear mode. Experiment time is not more than half an hour and I need to collect data in every 5 seconds interval. Could someone please guide me to set the details? May I need to use labview or exporting the data directly from NI MAX will do the job?
