Multifunction DAQ
NI DAQ 6368/6378 Card is not capturing complete waveform on AI channel
I am using NI DAQ Card 6368 and 6378 for Analog signal acquisition and saving waveform in .tdms file. Below are the settings for AI channels:
Sampling rate:1MS/s
No. of AI channel: 16
Samples per channel: 5MS
Sampling mode: Continues
System RAM: 16GB
Capturing time: 105% of the total waveform time
I am not able to capture complete waveform with these settings. Please help me if anyone know the solution.
(2,214 Views)
What do you mean by "I am not able to capture complete waveform with these settings."
The sassy response would be "just acquire for longer," but I suspect you're probably getting an error or something like that, else you probably would have already tried acquiring for longer 😉
Please give us a detailed description of your problem and the code or some screenshots that show the behavior.
(2,160 Views)
