05-18-2012 07:31 PM
I am using the DAQ 6281 for the first time. I need to acquire the data from it and save it into the Excel format. I want to connect the keithley 2306 battery simulator with the DAQ 6281. Can anyone help me how to make the setting work...
05-23-2012 09:27 AM
Sure! This forums intention is to help people using National Instruments Products!
Christian
05-23-2012 09:31 AM
Hi Christian,
Can you give me a description of how to use the Keithley 2306 Battery simulator with the NI 6281 DAQ module. The main problem is about Keithley interfacing with the DAQ.
05-23-2012 09:49 AM
What exactly are you trying to do? Just measure the output voltage of the Keithley? The output current?
05-23-2012 09:59 AM
We need to connect the Keithley to a mobile, need to note down the voltage and current of the mobile using DAQ.
05-23-2012 10:37 AM
I'm not sure why you would use a DAQ card instead of a GPIB interface to the Keithley.
The 6281 can only measure voltage so you would use one channel for the voltage and then measure the voltage drop across a known shunt resistor and calculate the current.
05-24-2012 02:10 AM
Maybe they don't have a GPIB device available to interface the Keithley instrument.
Christian
