01-02-2019 04:06 AM
Hi
I just purchased a NI 9862 CAN module to use in my cDAQ 9172 but the module is not recognized in MAX. I use XNET 14.5 (because I have Labview 2011 this is the latest supported version). According to the documentation NI 9862 is supported by XNET14.5
What to do?
NI support report attached
Regards
Mads Nygaard
Dinex
MAX Configuration Report:
Solved! Go to Solution.
01-02-2019 09:36 AM
The 986x modules are not supported in the cDAQ-9172 (Legacy). See the C Series Module Compatibility Chart.
The cDAQ-9172 was the first generation of CompactDAQ chassis and lacks certain hardware features needed for newer C Series modules. The cDAQ-9178 is its direct replacement. (Or, if you're willing to rearrange things, the 986x modules will also work in the 9171s you have.)
01-03-2019 01:48 AM
Hi Brandon
Thank you for the reply. I hadn't found that overview in my search.
Guess I need to make an investment 🙂
