12-18-2012 11:37 AM
The question i want to ask is that whether NI 9265 (analog current output module) is compatible with
compactDAQ or not.
The comparison tables shown in the attached pdf files, "NI-Datasheet-ds-219.pdf" says no compatibility
for compactDAQ.
And in the other pdf "NI-Datasheet-ds-220.pdf" says compatibility "yes".
Which one is correct?
Waiting for urgent reply...... Thanks
12-19-2012 03:54 PM
Hi Waqar123,
I am sorry about the confusion. According to the documentation below, the NI 9265 is compatible with the CompactDAQ and CompactRIO.
http://www.ni.com/white-paper/8136/en
Also, on the product page linked below, under specifications it is listed as both CompactDAQ and CompactRIO Form Factor.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/208808
The 9265 is compatible with with both CompactRIO and CompactDAQ. It seems that the NI Datasheet ds 219.pdf which you linked in your post is incorrect and I will work on having that fixed. Thank you for bringing this to our attention.
