Multifunction DAQ
NI 9402/cDAQ9185 How to dynamic change a dutycycle of a fixed frequency output
Hi.
I have a NI 9402 were I need to dynamically change the dutycycle "on the fly" on a predefined digital output frequency (up to 2kHz).
Is this possible with a cDAQ or will this require a cRIO solution?
(1,782 Views)
Accepted by topic author uf
You should be able to do this with a continuous counter pulse generation task using DAQmx on a cDAQ.  cRIO shouldn't be necessary.
You'd use one of the chassis counters and route its output to a DO pin.  Note that you may need to write both freq *and* duty cycle together to make the duty cycle change "take hold."   See this thread for more info.
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(1,723 Views)
Many thanks Kevin 🙂
I got it now
(1,702 Views)
