Multifunction DAQ
NI 9402/cDAQ9185 How to dynamic change a dutycycle of a fixed frequency output
Highlighted
Hi.
I have a NI 9402 were I need to dynamically change the dutycycle "on the fly" on a predefined digital output frequency (up to 2kHz).
Is this possible with a cDAQ or will this require a cRIO solution?
(147 Views)
Accepted by topic author uf
You should be able to do this with a continuous counter pulse generation task using DAQmx on a cDAQ.  cRIO shouldn't be necessary.
You'd use one of the chassis counters and route its output to a DO pin.  Note that you may need to write both freq *and* duty cycle together to make the duty cycle change "take hold."   See this thread for more info.
-Kevin P
(88 Views)
Many thanks Kevin :-)
I got it now
(67 Views)
