NI 9401 with NI DAQmx
  I'am I new user of the DAqmx, I use a Ni 9401 ( 8 DIO, 5 V/TTL, Bidirectional, 100 ns) to have angular speed spped with a NiCdaq 9174.
  I start doing a Labview VI but I have some errors, the first one is as shown in the picture.
  If somone used with the NI 9401 can help.
Thanks a lot,
 Firestorm100
(560 Views)
You've selected an incorrect channel for the DO operation - you should be selecting DO channel of 9401, instead you have selected a AI channel of some other module
-Santhosh
Semiconductor Validation & Production Test
Soliton Technologies
NI CLD, CTD
LabVIEW + TestStand + TestStand Semiconductor Module (2013 - 2020)
NI STS for Mixed signal and RF
(537 Views)
What you have in cDAQ1Mod1 is an analog input module and you cannot configure a digital Output task with it.
Saludos.
(535 Views)
Thank for you answer. the problem that when I want to choose my physical channel , I Have olnly ( cdaqmod1 and cdaqmod2 :  I have other card) Not the cdaqmod3 ( NI9401 position):
(516 Views)
Looks like you reused a DAQmx AI example and the control is filtering only AI channels.
Try deleting the control and creating a new one from the Create DAQmx Task API.
-Santhosh
NI CLD, CTD
(513 Views)
Thanks a lot, I will try this
(492 Views)
