09-24-2017 03:14 AM
Hi Everyone
I have NI 9265 analog output module. I have just learnt that it produces current output 4mA - 20mA.
The problem is that I bought this module to control a motor driver which run with a potentiometer by increasing or decreasing its voltage.
The motor driver runs between 0V - 10V.
So I thought that I can remove this potentiometer and control the motor driver with NI 9265 programmatically.
But it gives current output.
So what can I do??
09-24-2017 07:25 AM
There are industrial parts out there specifically for converting between 20mA and 10V signals. As a quick and dirty, you could just use a 500 Ohm resistor in parallel with your motor control (500 Ohm * 0.02A = 10V).
Or you can just get a NI-9263, which can output -10 to 10V.
09-24-2017 07:43 AM
Thank you sir.
