08-01-2018 02:45 PM
What are the differences between the two NI-9263 modules?
783740-01 vs 779012-01
https://www.ni.com/en-us/shop/select/c-series-voltage-output-module
All the specs appear to be the same and the prices are the same.
783740-01 |
NI 9263 Spring Term, +/-10 V, 16-Bit, 100 kS/s/ch, 4-Ch AO Module |
$455
779012-01 |
NI 9263 Screw Term, +/-10 V, 16-Bit, 100 kS/s/ch, 4-Ch AO Module |
$455
Thanks!
08-02-2018 03:37 PM
One is a spring terminal and one is a screw terminal. You have it listed in the description you posted
So just different options on how to connect the wires.
08-02-2018 03:49 PM
wow! i totally read spring and screw as the same word. thanks for pointing that out!
