03-05-2020 12:32 AM
03-05-2020 08:35 AM
You're running into an inherent property of the Delta-Sigma converters used by those devices. They have filtering in the signal path that induces a delay which is defined in their respective spec sheets. There's a small delay from the analog filter and a generally much larger delay from the digital filter.
It so happens that the 9229 and 9234 have almost identical input delay specs, differing only by 700 nanosec in the analog stage. The 9232 has a similar analog delay, but its digital delay differs from the others by 10-12 samples depending on some "decimation" setting. (I'm not personally familiar with that module.)
Note: the digital delay for the 9229 and 9234 is stated as (40 + 5/512) / fs. The numerator represents a # of samples, dividing by the sample rate fs converts to units of seconds to match the units of the analog delay. The digital delay for the 9232 is stated as either 30,29, or 28 / fs, making your 12 sample discrepancy make a lot of sense.
It's up to the programmer to use knowledge of these delay specs to compensate. Here's some more info.
- Kevin P
03-05-2020 05:16 PM
Thanks Kevin. If I use the same settings, including sample rate, is it safe to assume that the offset will always be the same? If so I can work around it easily enough, or just ignore it.
My main concern was the possibility that the offset will drift, so that if I am logging for a long period of time the time offset increases.
03-06-2020 07:25 AM
Yes, the offset should remain constant. All the modules will be getting their sample clocks from a common souce in the chassis, so there won't be any further skew over time. Just the constant fixed delay difference you've already seen.
-Kevin P
03-06-2020 11:10 PM
Thanks again Kevin.
03-08-2020 11:50 AM
Don't know how the Matlab nor the Signal Express toolkits work, but, in LabVIEW you can combine all three modules in a single task, with the same sampling rate, and they are synchronized if they are in the same chassis.
In Matlab don't make separate tasks, make a single task that contains all three boards.
mcduff
