Multifunction DAQ
NI 9219 Calibration procedure
Greetings,
I'm currently using a c-RIO 9054 with a NI-9219 module. Since the external calibration is almost expired, I've tried to re-calibrate the module by following the procedure explained in the DataSheet. By following the step-by-step procedure I've build the VI ( attach below).
The problem is that even if I was calibrating at low voltage, two channels are blind now and  the real don't fit the real voltage. I) don't think I burned the channels because the voltage I was using was  around 1 V but now I don't know how to fix this.
Thank you in advance for your advices.
Best regard,
Nando
Message 1 of 1
(755 Views)
