07-01-2009 01:41 PM
i am using two ni 9205 devices to acquire voltages. When i connect only one fo the devices all seems to be ok. When i conncet the second device i can not read the correct value for voltage. I had read that changing the sample rate and convert clock would help, but i dont know how to do this.
Anyone can help me?
The Ni 9205 are connected in a NI cDaq-9172 device.
07-02-2009 10:23 AM
Maybe this post can help you: Incorrect analog values from NI 9205 in multichannel mode
Aurélien J.
National Instruments France
07-02-2009 11:03 AM
Hi i had read that message but i don't undesrstand how to change the samplig rate and the convert clock?
Do you know how to do this? I am trying to do the modification in the VI suggestd in that message but returns an error.
Tahnks for your atention
