Multifunction DAQ
NI 9205 False Readings
I have a NI 9205 that I am using with the cDAQ chassis 9174 and Flexlogger. With this setup I am attempting to use every channel in a Non-Referenced Single Ended configuration, per the getting started guide, where every input channel is receiving an input from a 5V pressure switch. After going through and tuning the switches to the set pressure I will go to test a channel in the middle, lets say A6, all the channels above A6, ie A5, A4, A3..., will go the same direction that channel will go HIGH/LOW. I have double and triple checked my wiring for any shorts, could my 9205 or spring terminal be faulty?
Thank you in advance.
Message 1 of 1
(746 Views)
