01-27-2021 03:23 AM
Hi
I have the NI-9025 C module with a push-in spring terminal and I am looking to replace the spring terminal with a screw terminal adapter like the Model: NI-9923.
Aviram
01-28-2021 01:47 AM
Hi Aviram,
You want to replace connectors marked with red in the photo or it is not your device?
Anyways, take a look also at this link:
https://www.ni.com/en-us/shop/accessories/products/terminal-block-plug.html
01-28-2021 05:58 AM
Hi
This is the connector I would like to replace
01-28-2021 08:33 AM
Hi Aviram,
According to NI webpage, NI9974 is 36 position female combicon screw terminal. This should replace the push-in spring terminal that you have.
before purchasing it contact NI support to ensure if there is no error on the webpage and it is indeed a screw terminal.
The photo on the webpage corresponds to push-in terminal.
Alternatively, if you have purchased your module recently, ask NI if it is impossible to replace one with D-SUB output.
06-18-2021 04:54 PM
Could you please tell me how to insert wires into this type connector?
It is the spring terminal block. I insert screw driver into the inside hole to open the terminal, but I find it is not open---wire cannot be inserted into the outside (orange) hole.
06-19-2021 09:23 PM
Some more information,
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Qk7SAE&l=en-US
Accessory compatibility guide - https://www.ni.com/en-us/support/documentation/supplemental/17/c-series-with-spring-terminal-front-c...
To buy - https://www.ni.com/en-us/shop/accessories/products/terminal-block-plug.html?skuId=112003
06-19-2021 09:24 PM
Hi M_Huang,
Please refer this article on how to connect wires to spring terminal - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIcVCAW&l=en-US
06-19-2021 09:31 PM
Hi Santhosh,
It is really helpful for me.
Thanks a lot.
Mian
