03-03-2011 11:06 AM
Don't forget to take into account the ~144Kohm input resistance of the 600x's analog channels.
Or add a unity gain buffer with a high input impedance.
-AK2DM
03-04-2011 05:50 AM
My dear Frank L
Thank you for your response. you are so kind. Can you please give ur mail id so that i can contact you ?
Thanks and regards,
Debashis Dutta
03-07-2011 11:04 AM
Debashis,
Unfortunately, we cannot distribute any of our personal information through the discussion forums. However, if you would like to be contacted for a resolution to this problem, we can look up your information from you NI.com user ID if we have your permission. I would then be able to contact you to continue troubleshooting your issue. If you have other questions not related to this issue, feel free to call in to our support line from ni.com/support and another Applications Engineer would be glad to assist you! Thanks!
03-16-2011 11:07 PM
Frank
Thank you for ur promt reply. I would like to be contacted. Carry on whatever is required. I want to be in touch with you.
Thank you once again.
Debashis
03-17-2011 12:08 PM
Debashis,
Unfortunatly due to the way that the phone support system works along, the best method for you to get a timly response would be for you to create a service request from ni.com/support and you will be able to get in contact with me or another applications engineer to better assist you! Thanks!
02-08-2012 06:28 PM
... had the same problem several years ago. We use the USB-6008 and 6009 in different applications in the lab and for commissioning purposes. I used to build input amplifiers with operational amplifiers for every application. Took a lot of time until it worked.
After a while I decided to build a 'final solution', which now became rather final with revision 03.
A small PCB contains an 8xAin and 2xAout precision operational amplifiers with power supply. See more at
https://sites.google.com/a/loster.com/mc-add-on/
We like the 6008/9 interfaces because they are reasonably priced and good for most applications especially for A/D conversion if it is not toooo realtime. Using the preamplifier made software design much easier for not recalculating the measured values and the applications seem to work much more stable. So we use them now in every application. They simply plug in between the terminal connector and the USB-600x interface.
03-11-2014 09:27 AM
I'm having the same problem with the DAQ6009 when trying to read voltages from strain gages. I was wondering what you would recommend as a replacement DAQ if I chose to go that route. Ultimately the specs I would like to have would include: 2 analog inputs, 2 counter inputs, and 1 digital output. I'd like to ensure that I was reading the correct signal, but have a reasonable price. Do you have any recommendations?
03-13-2014 08:24 AM
First off, you are commenting on an old thread, it would be better for you to make a new post and reference this one in the future.
Are you looking for another USB device? If you would like to PM me, I can help you pick one out and get you in touch with someone who can write out a quote.
