Multifunction DAQ
NI 6008, Measurement Computing usb-201
So i need daq module i choose this two as similar. Have anyone use USB-201 ? what are pros and cons, price is for sure the pros
and i have pressure transducer http://peltron.pl/wp-content/uploads/2015/04/NPC.pdf ( is in another language )
The power supply for output signal 0-10V   (the one i choose and USB-201 is for voltage input only) is 15÷30 V three wire so schematic on the left
So how should i connect transducer? the usv-201 is power by usb 5V
i connect one wire in analog input in modeule and groud an powre transducer by external powwer suplay with voltage range 15÷30 V ?
(2,235 Views)
怎么发布的贴子?在论坛找了半天都没找到!
(2,162 Views)
