04-25-2012 04:06 AM - edited 04-25-2012 04:15 AM
I’m using a NI 5105 in TestStand sequences (4.1) on a testbench. It was fine (Timing tests ran ok meaning the scope was working fine at that moment) until I got back to work 2 weeks ago and nobody turned the testbench computer on. It is now showing the following error on every step involving the scope:
An exception occurred calling 'RunStep' in 'ISubstep' of 'zNI TestStand Ivi Step Types'
An error occurred while executing the step.
Component Works IVI Control Error: The IVI Read operation failed on channel 'CHANNEL0' for logical name 'PXI_SCOPE_1'.
Details: (CHANNEL0) NI Platform Services: A synchronization object was not acquired within the time limit. The operation could not be completed as specified. Status Code: -50550 [IVI Error Code: BFFA65D9]
Source: TSIviStepTypes
After some research on NI Forum, here are the solutions I found:
What does this error mean ?
How can I fix it ?
PS : My apology if it doesn't belong to this board, can an admin please move it to the correct one. Thanks.
04-26-2012 02:45 AM
Please delete this thread as it was re-created in the correct board :
http://forums.ni.com/t5/High-Speed-Digitizers/NI-5105-returns-error-50550/td-p/1966865
