Could you just look at this vi and tell me if i am doing anything wrong? I get errors that are different each time I change something. here are the inputs I am using
Output Side:
amplitude = 1
freuency = 50kHz
Sampling Frequency = 1MHz
3 of Samples = 200
Input Side:
Input Buffer 4000
trigger type = analog
pretrigger = 5
edge or slope = rising
scan rate = 500kHz
# of scans = 2000
Conditional Retrieval
mode = on
slope = rising
skip count = 0
level = .1
offset = 0
hysteresis = 0
So what we want to do is capture the ten
cycles of the 50k output pulse on the input and need to store that so we can plot it later, do you have any suggestions. we are using the PCI-MIO- 16E board.
Jarrod
