Multifunction DAQ
My output voltage is not stable while using DAQ and AE sensor
HelloGuys,
I use "physical accoustic groups R15" as an AE sensor with "USB6251 DAQ" to sense the acoustic esmission of a sound wave
Everything goes well, for example when I apply a tap  to the sensor, I can see the correct output but the problem is that the output is not stable, even when I have no input, the output voltage changes slowly toward -10 or +10 although it shoud oscillate around zero.
Thanks for your help,
Ela
(3,413 Views)
Do you have the sensor ground connected to the Analog Input ground?
-AK2DM
(3,412 Views)
YES
(3,410 Views)
Does the sensor use an amplifier or have one built in?
Can you attach a manual or spec sheet for the sensor (an amplfier if required)?
A quick description of how you have it all wired up, including pin #'s of the DAQ card.
-AK2DM
(3,404 Views)
I attached the datasheet for R15a but I use R15 both are the same.
There is no built in amp, and I have not used the preamp.
I have used the bnc cable to connect the sensor to one of the analog input pins and connect its ground to the DAQ ground.
Thanks for following up my problem.
(3,397 Views)
I have used pins # 1 & 3
about built-in amp, I'm not sure. We had that sensor in lab from years ago and I used it. The datasheet doesnot provide enough info.
(3,395 Views)
Ela:
It looks like you need an amplifier for that unit. The sensor alone probably has a very high output impedance which is probably causing the input end of your DAQ card to build up a charge, that is why you set it drifing to the rails over time.
You could try connecting the sensor to the DAQ in the differential mode of operation using a pair of bias resistors, refer to the manual of your DAQ to see how to do this.
-AK2DM
Message Edited by AnalogKid2DigitalMan on 02-05-2010 09:06 AM
(3,359 Views)
