10-06-2009 04:08 AM
I finish a Labview project and when install the solution on the client PC, it doesn't work and send me this error code 2564.
The error code referents to a labview plug-in and i doesn't found it in the NI website.
Anybody knows which component I mus to include to the instalable version?
Solved! Go to Solution.
10-06-2009 09:27 AM
10-06-2009 10:51 AM
I have a USB 6221 device in my project
I build an executable and this file works well in my computer, later I buid an instalable and include these options :
-NI Run-Time engine 8.6.1
-NI-DAQmx 8.8
-NI-VISA Run-Time 4.4
and when install the volume in other computer and try to execute the exe file apears the message with error code 2564.
10-06-2009 11:19 AM
An error of -2564 points to something wrong with the Storage VIs. There is an additional installer called NI USI for Universal Srorage Interface. Try including that.
p.s. Paste any error code into an error cluster and right click on the code and select 'Explain error'.
10-07-2009 01:55 AM
Hi Moisés,
Dennis is right. Read this KB: http://digital.ni.com/public.nsf/allkb/B2045400ECC627F1862571EA005A6B6E?OpenDocument
So, rebuild your installer including that and check that this error is fixed.
Saludos. Jesus
10-08-2009 07:24 AM
Now, I add NI USI 1.6.0 to my instalable and the error code 2564 desapears.
But the aplication not work.
The message is this
I think the problem is in USB 6221, and the new computer detects the hardware but when i try to capture analog imputs with it doesn't work.
10-08-2009 09:59 AM
10-08-2009 10:58 AM
Hi Moises,
why don't you try to add MAX configuration when creating the installer. Save the nce file to load the configuration later. See the screenshots I send you.
Saludos.
Jesus
10-09-2009 02:20 AM
Thanks a lot for your help.
I do it all you explain me, and the system doesn't work.
Now all the aplication works but I don't receive signal from USB 6221.
I open MAX in the new computer and test the device, and the device works ( I see a graphical in the analogical input).
Maybe there aren't all of components of hardware device to connect it to my aplication .
10-09-2009 02:29 AM
Hi Moisés,
read the following piece of information:
Error 201003 is generally caused due to the following reasons:
To resolve this error, carry out the following steps:
I hope this helps!! Saludos.
Jesus
