Multifunction DAQ
My instalable software generates an 2564 error code
In my aplication I register some Analogic inputs.
if the USB-6221 i not connected my soft generates an error, but if the USB-6221  is connected my software doesn't do anything wrong but not register nothing.
Now I try to make an simply example with only visualize an analogic input.
I need to finish the project untils this weekend.
Message 11 of 13
(1,005 Views)
Accepted by topic author moises
Good morning:
My executable doesn't work in the new computer.
I solve the error code 2564, but when generate an instalable version it doesn't work.
I use a USB 6221 Hardware and I try to capture a analogic input and I wan to graphicate this capture.
In the develop PC the VI rus perfect, but when I generates the instalable and install it in a new computer the executable doesn't capture anything.
Anybody Have an example to generate an instalable to capture Analog signal with USB 6221?
Message 12 of 13
(992 Views)
My problem is over.
The origin of the error is in a bad configuration of the DAQ task.
I choose anything in terminal configuration and the USB 6221  send me no signal, when I choose <let NI-DAQ choose > option, the aplications runs ok.
Thanks for your help
Message 13 of 13
(967 Views)
