01-13-2008 05:12 AM
01-14-2008 07:00 PM
Please view the link below and refer to the first two columns. It does lack proper labeling for the IEX (+) and (-), however it is close. I will dig deeper for the correct pin out, however this one should help for now.
AE KB 1SDDOSPH: Cable Mapping for a 68-Pin Connector to a 50-Pin Connector
01-15-2008 04:13 AM
01-16-2008 01:26 PM
The 25DB to 36 pin pinout is linked below. This link does not correlate to the DAQPad-MIO-16XE-50. I would suggest looking at the DAQPad-MIO-16XE-50 User Manual provided below. Appendix B in this manual is helpful for troubleshooting parallel ports. In addition, I am also curious to know what operating system and version of drivers are on the PC you are connecting to the DAQPad. The DAQPad-MIO-16XE-50 is not supported on Windows XP or NI-DAQmx driver.
If you are using LabView, I also found an example program to help with your testing. Under the Help Menu select Find Example to launch the Example Finder. The title of the example is Parallel Port Read and Write Loop.VI. Please note that in the tab titled I/O Connector Status, the LEDs still receive correct data in relation to the number labels even though the orientation of the LEDs are incorrect. The orientation of the LEDs is incorrect, since they do not match the pinout order of an actual 25DB connector.
Parallel cables pinout and port info
01-22-2008 05:30 AM
01-22-2008 10:38 AM
01-22-2008 10:38 AM - edited 01-22-2008 10:38 AM
