Modifying NI9205 to make arrangement less crowded
Our research group is currently designing a 6x6 photodiode array on a PCB and intend to use the NI9205 device to acquire all 36 channels. One issue that we are consistently running into is the fact that the push-in style spring terminal is not large enough to fit all of the dupont wires. We are wondering if there are any alternative terminals/approaches that would help us around this. Any assistance into this matter would be greatly appreciated. Thank you!
(235 Views)
NI-9205 Getting Started:
The NI-9205 with spring terminal is available in two types: push-in spring terminal and spring terminal. The push-in type spring terminal connector is black and orange. The spring terminal connector is black.
I think you can replace it with the Spring Terminal Connector
(216 Views)
