07-22-2011 02:55 PM
I have a modbus device that is currently working but it is giving me inconsistent readings. The modus device has thermocouples that I am reading as a shared variables that outputs voltage readings. I am subtracting the voltage reading that corresponds to to 0 degrees from the shared variable reading and multiplying a calibration constant to convert the voltage readings to temperatures. I can't figure out why the readings are inconsistent. I have attached the program for better understanding of the system. Any suggestion on what to do. Thank you for your time.
07-28-2011 10:20 AM
