Multifunction DAQ
Mixing Differential/RSE Inputs on NI-9209
I am wanting to use a NI-9209 cDAQ module to take some differential measurements.  I will not be using all of the differential channels on the device and I have some other single-ended measurements that I need to do as well.  Can differential and single-ended inputs be done on the same module, assuming the proper wiring connections are made?  For example, could I do a differential measurement using AI0/AI8 and then do a single-ended (RSE) measurement on AI10?  Is the differential/single-ended configuration at the module level or is each channel configurable?
(354 Views)
I would just do differential on all signals, even if they are single-ended if I have enough channels.
Santhosh
Soliton Technologies
(327 Views)
Accepted by topic author mklusman
Simultaneously Acquiring Data in RSE and Differential Modes in LabVIEW says that you can do that. If you want confirmation, you can Create Simulated NI-DAQmx Devices in NI MAX and test it out.
(323 Views)
