Multifunction DAQ
Missmatch on value read after writting a value using C++ (NiDAQmx)
We have written a value (2v) to an output channel AO1 and was verified the value in hardware (voltmeter).  The channel AO1 is wired to the input channel AI3.  But when we read the value of AI3, we do not get the value that we have writtem. We have tried the behavior with and without a triggering source. In both cases, we did not get the value written to AO1, when reading from AI3.
The C++ code used for Analog value reading and writing is given below. Is there any issue with the below code?
Read analog
TaskHandle oTask;
constexpr char TaskName[] = "";
double fRead{ 0 };
int32 nError = DAQmxCreateTask(TaskName, &oTask);
nError = DAQmxCreateAIVoltageChan(oTask, "Dev1/AI3", "", DAQmx_Val_Cfg_Default, -3.25, 3.25, DAQmx_Val_Volts, nullptr);
nError = DAQmxCfgSampClkTiming(oTask, "", 1.0, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, 2);
nError = DAQmxCfgDigEdgeStartTrig(oTask, "PFI0", DAQmx_Val_Rising);
int32 nError = DAQmxReadAnalogF64(oTask, 1, 60, DAQmx_Val_GroupByChannel, &fRead, 1, &nSampsPerChanRead, nullptr);
nError = DAQmxClearTask(oTask);
Write analog
TaskHandle oTask;
double dValues[2]{ 2, 2 };
nError = DAQmxCreateAOVoltageChan(oTask, "Dev1/AO1", "", -3.25, 3.25, DAQmx_Val_Volts, nullptr);
nError = DAQmxCfgSampClkTiming(oTask, "", 50.0, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, 2);
nError = DAQmxWriteAnalogF64(oTask, 2, 1, 60, DAQmx_Val_GroupByChannel, dValues, nullptr, nullptr);
nError = DAQmxWaitUntilTaskDone(oTask, 60);
(906 Views)
Accepted by kiran_t
Sometimes this kind of thing is due to a mismatch between the terminal configuration (RSE, NRSE, differential) and the physical wiring.   You can use test panels in MAX to experiment with the configuration, and here's a summary about the recommended physical wiring.  (The classic, more thorough article can be found here.)
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(873 Views)
