Multifunction DAQ
Missing Property Node(s): AI.ADCTimingMode
I have some old code (LV 2017 DAQmx 19.6) that use the AI.ADCTimingMode & AI.ADCCustomTimingMode property nodes. I am trying to recreate this code and have found that I cannot access these property nodes (among others) through manual creation. I have also tested this on a different VM with LV2020 & DAQmx 20.0. The online documentation eludes to a DAQmx 20.1, however, I have not been able to find a download for that version.
I am able to view the property nodes through the class browser, but it does not let me select them:
After clicking OK, the node does not show up in the class browser
Documentation: http://www.ni.com/documentation/en/ni-daqmx/latest/daqmx-prop-ref/task-ai-adctimingmode-29f9/
Can anyone help me access these property nodes "from scratch" (ie manually, not by copying the existing code)?
Attached is a VI with the property node pictured above (saved in LabVIEW 2017, though I have also tested this in LabVIEW 2020).
(2,180 Views)
Accepted by skaley
Sometimes it is filtered for certain devices, please try removing the filter by
  3. Now you should be able to select the property
Santhosh
Soliton Technologies
(2,144 Views)
