08-07-2020 08:39 AM
I want to measure the 24V AC signals coming out of a wall mounted thermostat in my home for heating, cooling and fan. NI daqs as much as I know have an input voltage range of -10 to 10 V. Any suggestions on how I can use an NI daw to measure these signals?
08-10-2020 01:42 AM
Hi MeasureGeek,
In order to make 24V AC measurements, you may connect the right DAQ device hardware/module which match the input range of your signal.
Here's the C series Voltage Input Modules link with all the listed Analog Input Voltage Range respective to each module:
https://www.ni.com/en-my/shop/hardware/products/c-series-voltage-input-module.html?modelId=122157
Be sure to check whether the module is Input AC or DC Coupling, if it's DC coupling, the module supports both AC and DC signals to pass through a connection whereas AC Coupling only allows AC signals. You may refer to the link below for detailed explanation regarding to Input Coupling:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019O6oSAE&l=en-MY
