01-12-2010 04:47 PM
Solved! Go to Solution.
01-13-2010 01:15 PM
Hi Jamesu,
DAQmx should support both devices--which version of each DAQ driver do you have installed? One helpful piece of information to gather would be a report of the NI Software that you have installed on your system (you can do this from MAX by selecting File » Create Report). You also might want to take a look at the following KnowledgeBase articles. This problem can be seen when the MAX database is corrupt or when necessary services are not running:
NI Device Loader (nidevldu) and NI Configuration Manager Services Not Starting
Best Regards,
01-14-2010 05:27 PM
John,
Thank you for the tips. I tried them, but unfortunately without success. I also upgraded the pc in question to WinXP SP3, to no avail. Finally, in our collection I found another PCI-6071E and replaced the original card. The new card works - MAX recognizes it. I will have to see about getting the first card repaired. However, I'm up and running again.
Jim
