Multifunction DAQ
MAX not seeing PXIe-4300
Greetings,
The PXIe-4300 cards are not seen by MAX. After DAQmx 9.7.5 is repaired, the cards are then recognized and the tasks work fine. After restart the problem re-occurs until DAQmx is repaired again. No issues with other PXI/PXIe cards in the 1062Q Chassis. Any solutions?
Measurement & Automation Explorer 5.5
DAQmx 9.7.5
(2,626 Views)
Hello Frank_at_Cal-Matrix,
Has this setup worked correctly before? When did this start happening? Is there a specific reason you are using DAQmx 9.7.5 and not a newer release?
Aside from that, if you have a system restore point I would recommend trying that. I would also recommend sharing which controller you are using with your PXIe system.
All the best,
(2,597 Views)
