08-29-2012 02:40 PM
I'm trying to take some 3rd party acquisition code written in C for the NI PCIE 6323 X Series DAQ on Windows and port it to make it run under Linux (CentOS 6.3 == Red Hat Enterprise Linux 6.3). I have the board installed, and I successfully ran the DAWmx802f0.iso installer, but neither lsdaq nor nilsdev sees any NI hardware attached to my machine. (I rebooted after installing.)
I see the original Windows code used headers and libraries from NI-DAQmx 9.2, but the only Linux version of the software I could find was 8.02. Is it possible to use the NI PCIE 6323 X Series DAQ on Linux? Is it compatible with the NI 8.02 software? If so, how should I go about troubleshooting my system so that lsdaq or nilsdev can see my hardware?
Thanks.
08-30-2012 05:38 PM
Unfortunately the readme.txt file for the DAQmx 8.0.2 driver seems to indicate that it does not support the PCIe 6323. In addition I looked into the DAQmx Base run-time environment for linux as an option but it also does not support the PCIe-6323.
Isaac S.
