Multifunction DAQ
Linking Borland C++5.0 & NIDAQmx 8.6
Developed code for the PCI DIO96 card in VC++ using NIDAQmx 8.6.
Code works.
Rewrote code to work with an old old program written in Borland C++5.0.
Used NIDAQmx.lib for linking.
I received an error:  nidaqmx.lib contains invalid omf record.
From the forum, I see techniques for linking NIDAQ 7.4.
Could not find the NIDAQ32.dll in the forum discussions.
How can I link Borland C++5.0 with NIDAQmx 8.6?
(3,515 Views)
Welcome to the discussion forums, RogerBerchtold!
Although not officially supported, there are a variety of KnowledgeBases (KBs) and other discussion that can offer some help to work with Borland.
The first KB to which I want to point you is How Can I Use the NI-DAQmx ANSI C Function Library with Borland C and Delphi?
The KB Can I Make NI-DAQmx Calls From Borland Delphi? has a zip file for DAQmx 8.6.
Hopefully that will get you pointed in the right direction.
Mark E.
Precision DC Product Support Engineer
(3,494 Views)
