I have been developing an application using Borland C++ Builder 3 and need
to integrate a DAQCard 6533 into the
application using NI-DAQ 6.7.
Before trying to use the DAQCard 6533
I have written a small test program
that simply calls the function Get_NI_DAQ_Version to get the version of NI-DAQ
installed. When I try and run this program I get the following error.
The NIDAQ32.DLL file cannot start. Check the file to determine the problem.
What is the problem, and what can I do to fix it?
regards
Trevor Jackson
