03-01-2006 11:10 AM
03-02-2006 01:52 PM
Nick,
I believe you are correct in your reasoning behind the error. Because USB
devices require interrupts to pass the data of the device, if no processor time
is available to fill the request these types of errors can occur.
Instead of having to redimension the array, and forcing LabVIEW to copy the
data to a new memory location, you could initialize the array to a predefined
size at the beginning of your application. For example if you wanted to
record data for 1 hour at 2 samples a second you would initialize the array to
have 7200 elements. In each iteration of the array you would then insert
into a specific element. This would allow you to keep track of all the
data. Another alternative is to store that data to a file, and only keep a
smaller history for your graph. For example you could record data for 7+
hours into a file, but only keep the last 30 minutes of data in the
graph. Once the application has stopped you could do post processing on
that data when time is not as critical.
Jesse O.
Application Engineering
03-02-2006 04:30 PM
03-03-2006 03:25 PM
Nick,
It is more efficient to allocate the entire array before your while loop, and
use the replace array subset vi to fill it in. You can find information
on this here:
http://zone.ni.com/reference/en-XX/help/371361A-01/lvconcepts/vi_memory_usage/
under the heading "Avoid Constantly Resizing Data". If you need
to add the data point to location 120001 you need to use the insert into array,
and this will reallocate all the memory in LabVIEW. As the document
demonstrates with the build array, this is very time consuming.
I do not think that going to USB 2.0 will help you past this problem because
the issue seems to be with the processor. It sounds like the processor is
not fast enough to keep up with the memory allocation/copying of data and
handling interrupts.
To find out how many samples remain in the buffer, you can use a DAQmx Read
property node. In this property node select Status >> Available
Samples Per Channel.
Jesse O.
