Showing results forĀ
Search instead forĀ
Did you mean:Ā
LVDT not reading
Hello all,
I have a Hampton VA HR 100 LVDT sensor. I want to measure the position of a rod within the LVDT sensor (displacement). I am new to Labview, but I managed to get a VI working.
My first issue is that I cannot select the device as an LVDT Analog input, rather, it must be read as a Voltage input when I start up the DAQ assistant on the VI. That works, however, the movements of the rod seem to indicate an acceleration rather than a position change. I have attached the graph of the VI that I get for 10 samples at 100 Hz. I also attached the VI. I need to get it to read it as a position, hence the voltage reading should indicate a displacement, and not just go back down as soon as I stop moving the rod.
I am using a NI USB-6009, with grounds connected to both the 5V pin digital side and the analog side. Any help is appreciated.
Thanks.
Alessandro Laspina.
(4,227 Views)
A LVDT need a constant amplitude sine exitation and a 'lock in'/sync readout to measure a distance. Can't supply a link, but get the physics on how the sensor work, and you migth find that it's hard to do with a 6009.
With the  software timed 150 SPS analog output of the 6009 I doupt that will get meaningfull readings without a LVDT signalcoditioner and a 6009 only. You can try an external sine generator and read LVDT  exitation and output ...I would try to use a soundcard to exite and read the LVDT šŸ™‚
Greetings from Germany
Henrik
LV since v3.1
ā€œgroundā€ is a convenient fantasy
'˙˙˙˙uıɐʃɐ lɐıp puɐ °06 ĒuoÉ„d ɹnoŹŽ uɹnʇ ĒsÉĒld 'ŹŽÉ¹Éuıƃɐɯı sı pĒlɐıp ĒŹŒÉÉ„ noŹŽ É¹ĒqÉÆnu ĒÉ„Ź‡'
(4,196 Views)
I am fairly sure I am providing a sinuisoidal wave input, but did not understand the lock-in/sync part. Why would I need a soundcard? The current setup should work (as it was done before): Labview,  USB DAQ 6009, and a circuit board I forgot to mention that connects the LVDT coil to the DAQ card. This board has a few capacitors and resistors but also an amplifier. The pin connections are correct, as nothing else reads it.
I am getting measurements whenever I rub the rub in the inner coil, but I think it isn't good in the long run for the sensor.
The LVDT has 6 wires out.
(4,187 Views)
I can't open your vi, so I can't see what's going on.... and unless we don't know what yourboard is doing....
For a LVDT you supply a sine exitation, the output (if propper wired) is a sine proportional to the feeding amplitude and the displacement . The lock-in/sync detect on which side of the zero (center position) you are  (phase turn 180°)
if you read exitation and sensor output (with high samplerate and at least 10 periodes, you can apply a tone detection and calculate the amplitude ratio and phase difference (last to detect sign)
Around zero you will read any phase, depending on how good the sensor and setup is šŸ˜‰
Henrik
LV since v3.1
(4,183 Views)
For sample rate, how high is high? I am using the convetion of having at least double the amount of sample compared to Hertz. Hence, I noted that the HR100 LVDT sensor is tested at a frequency of 2.5kHz. So I select 2.5kHz and provide 5500 as the sample rate.
I have tried now doing a voltage input with a sine wave excitation when using the DAQ assistant as opposed to just the Voltage input.
I have reattached the VI, let me know if you can open it.
(4,178 Views)
