09-17-2017 11:58 PM
Hello all,
I have a Hampton VA HR 100 LVDT sensor. I want to measure the position of a rod within the LVDT sensor (displacement). I am new to Labview, but I managed to get a VI working.
My first issue is that I cannot select the device as an LVDT Analog input, rather, it must be read as a Voltage input when I start up the DAQ assistant on the VI. That works, however, the movements of the rod seem to indicate an acceleration rather than a position change. I have attached the graph of the VI that I get for 10 samples at 100 Hz. I also attached the VI. I need to get it to read it as a position, hence the voltage reading should indicate a displacement, and not just go back down as soon as I stop moving the rod.
I am using a NI USB-6009, with grounds connected to both the 5V pin digital side and the analog side. Any help is appreciated.
Thanks.
Alessandro Laspina.
09-18-2017 05:48 AM - edited 09-18-2017 05:57 AM
A LVDT need a constant amplitude sine exitation and a 'lock in'/sync readout to measure a distance. Can't supply a link, but get the physics on how the sensor work, and you migth find that it's hard to do with a 6009.
With the software timed 150 SPS analog output of the 6009 I doupt that will get meaningfull readings without a LVDT signalcoditioner and a 6009 only. You can try an external sine generator and read LVDT exitation and output ...I would try to use a soundcard to exite and read the LVDT 🙂
09-18-2017 10:58 AM
I am fairly sure I am providing a sinuisoidal wave input, but did not understand the lock-in/sync part. Why would I need a soundcard? The current setup should work (as it was done before): Labview, USB DAQ 6009, and a circuit board I forgot to mention that connects the LVDT coil to the DAQ card. This board has a few capacitors and resistors but also an amplifier. The pin connections are correct, as nothing else reads it.
I am getting measurements whenever I rub the rub in the inner coil, but I think it isn't good in the long run for the sensor.
The LVDT has 6 wires out.
09-18-2017 12:02 PM - edited 09-18-2017 12:04 PM
I can't open your vi, so I can't see what's going on.... and unless we don't know what yourboard is doing....
For a LVDT you supply a sine exitation, the output (if propper wired) is a sine proportional to the feeding amplitude and the displacement . The lock-in/sync detect on which side of the zero (center position) you are (phase turn 180°)
if you read exitation and sensor output (with high samplerate and at least 10 periodes, you can apply a tone detection and calculate the amplitude ratio and phase difference (last to detect sign)
Around zero you will read any phase, depending on how good the sensor and setup is 😉
09-18-2017 02:25 PM
For sample rate, how high is high? I am using the convetion of having at least double the amount of sample compared to Hertz. Hence, I noted that the HR100 LVDT sensor is tested at a frequency of 2.5kHz. So I select 2.5kHz and provide 5500 as the sample rate.
I have tried now doing a voltage input with a sine wave excitation when using the DAQ assistant as opposed to just the Voltage input.
I have reattached the VI, let me know if you can open it.
