03-07-2012 05:51 AM
03-07-2012 08:44 AM
Berny,
Without seeing your VI, I can't really suggest much... However, I would recommend that you look for places where resources may be acquired but not released. This would include tasks or other references being created but not cleared, files which opened but not closed, or arrays which are continuously appended to in a loop. Have you watched memory usage as your VI runs?
Those are the first things that come to mind. If you can attach the code which reproduces this issue, I may have more suggestions.
Hope that helps,
Dan
03-07-2012 09:19 AM
thank you for your answer. This is the "smallest" piece of code, where i got the malfunction. I already got the hint, that i should not use the express-vi. I will test that an write again, could be that the permanent "open" and "close" of the card is not the best way 🙂
Thanks !
Greatings
03-07-2012 09:52 AM
Berny,
I can't really see how your DAQmx task is configured, but looking at your code, I would probably approach the problem as shown in my attached example. I do the following:
1) Open and setup the data file.
2) Set up a DAQmx Task, configured to run continuously.
3) Start the task running
4) Read two seconds worth of data
5) Append it to the existing file
6) Clear DAQmx task when done
7) Close file I opened.
Note that the DAQmx task is created and started only once, and the the file is opened and closed only once.
Hope that helps,
Dan
03-08-2012 03:16 AM
Hi Berny,
do you already have contact with the NI Support-Hotline?
If it is so, can you please tell me the SRQ vie private message?
Abdülkerim
03-17-2012 01:34 PM
Hi again,
i would like to ask again:
I tested quite a lot of things - here is the result:
The DAQ is written direct with DAQmx ( see attachment)
Now i have a different "crash" - labview is running, the digital ports of the card are working - just die anlalog in port is "froozen" - if i open all vi's there ist "no execution" in the DAQmx read vi ...
Stopping the program and start again "solves" the Problem
Can anyone help me ?
Workaround ?
Greatings
Berny
03-20-2012 02:24 PM
Berney,
A few more questions for you.
1) Do you see this behavior with both the 6210 and the 6361?
2) Does the DAQmxRead ever timeout (as specified it should be using the default value of 10 s)?
3) Is this issue still happening after 11 hours of run? Does the amount of time passed until you see bad behavior change if you change either the number of channels or the sample rate?
4) How many channels are in your task?
5) Are there multiple code paths being executed in parallel with the DAQmxReadLoop? Does the code attached exhibit this behavior when run by itself?
6) Have you seen any unexpected behavior with either CPU or memory usage prior to or during this observed hang? Does 'cycle-time analog read' stay fairly constant throughout the course of execution?
In your explanation, I think I'm missing what you mean when you wrote, 'if I open all vi's there ist "no execution' in the DAQmx read vi...' Does this mean that the DAQmx Read VI is not executing, or that execution is stopped inside the DAQmx Read VI?
I can try to reproduce similar behavior, however I'll need the answer to a few of these questions before I can do so.
Dan
03-23-2012 06:48 PM - edited 03-23-2012 06:50 PM
Hi Dan,
to your questions - because of the time delay it's not easy to test everything 🙂
no - just on the 6210 (see bottom )
default values 10s
its just approimately 11 hours , sometime a few days - it random i think
16 ( all of the card are needed)
i deleted all other loops - runs since 1 day - its not clear if that is the / one reason
No, that was also my first idea
Yes
BUT i found a way to generate this error very fast:
I opend the windows remote desktop connection (without a monitor on the PC), connected to the PC and than i unpluged the LAN-cable out of the PC - the card gets directly frozen, when i reconnect the remotedektop (after plug the LAN-cable in the PC) the cards are running again ...
( i tested also a reset of the card - it works - the cards run fine after that ; when i open and close the remote-desktop in the standard way - the card work also fine...
Do you have any idea why this happens - could be the same reason
Greatings
Berny
04-19-2012 04:53 AM
Hello Berny,
back to your attachments CC1 & CC2, is the sample clock rate 5000.00 or 5000,00?
The "sample per channel per read" can be round about 10% from your sample clock rate.
In this case 500 or 50000
http://digital.ni.com/public.nsf/allkb/3E3D74E26B8A5B83862575CA0053E4B5?OpenDocument
Hope that helps,
Christian
04-19-2012 05:09 AM
thank you - the number is 5000.00 - so 5000 samples/sec will be read - that works
greatings
Berny
