I have built a .VI to control the DAQmx PCIe6363. But when I am running it, getting an error with the code "Error- 200077 occurred at property node". The snap shoot of the same is attached files.
Can any one suggest to possible troubleshot to rectify the issue.
It would help quite a bit if you supplied you code. Otherwise we are just shooting in the dark.
But my wild guess is that you accidentally wired what you wanted to go to "Samples Per Channel" to "Sample Mode" on the DAQmx Timing VI.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
