Multifunction DAQ
Issue with DAQmx PCIe6363
Hi all,
I have built a .VI to control the DAQmx PCIe6363. But when I am running it, getting an error with the code "Error- 200077 occurred at property node". The snap shoot of the same is attached files.
Can any one suggest to possible troubleshot to rectify the issue.
(4,399 Views)
It would help quite a bit if you supplied you code.  Otherwise we are just shooting in the dark.
But my wild guess is that you accidentally wired what you wanted to go to "Samples Per Channel" to "Sample Mode" on the DAQmx Timing VI.
(4,390 Views)
Hello KNIGHT OF NI !!!
Thanks for your kind reply.
Find the attached block Prog. of the same.
P.S: Now I am testing Phase by Phase.
(4,371 Views)
