Is there a way to view the actual signal that is being sent over a RTSI line
I get an error:
Error occurred at: niScope Fetch.vi
Error Description: (Hex 0xBFFA4001) Software failure occurred during operation.
When I did some further testing I found that my scope card seems to be in the middle of an aquisition even though it should not be...
I would like to view via an oscilliscope the signal going across my RTSI line 1 becuase I am using a marker signal to trigger my cars across that line and I would like to see what the signal looks like.
(3,090 Views)
There is not a way to directly route the RTSI signal to the PFI line of our 5112 device. However, there may be another way we can view this depending on your system.
Can you give me some more information as to what digitizer you are using and what other devices you have in your system?
Brian
(3,090 Views)
We are using a 5102 NiScope card
We are also using a 5411 ARBWFGen
" " " " " 6713 AOoutput
The 5411 is generating two signals 1 for our experiemtns and a marker signal that is being routed over the RTSI bus. This marker signal triggers both the 6713 and the 5102.
(3,090 Views)
