07-29-2012 07:49 PM
I'm new using Labview software, so I'm having some difficulties.
I would like to know if there is any way of controlling the NI ELVIS II Function Generator using Labview.
I'm using the FGEN BNC of ELVIS to supply an eletrodynamic shaker and I need to measure the generated signal
and the response of the excited structure, so I can estimate a Frequency Response Function.
In order to do this, I need to trigger the input and output signals and that's why I want to control the FGEN
in Labview and not in the interface provided by NI ELVIS II.
I've been searching for similar problems but I couldn't find any.
I hope someone can help me.
Thanks in advance.
07-30-2012 10:01 AM
Hello mac87,
you can control NI ELVIS II using Labview through of the NI DAQmx Palette, NI SCOPE Palette or NI DMM Palette, depending of the resource which you like to use.
These links show any examples of applications with NI ELVIS and NI LabVIEW:
http://www.ni.com/white-paper/13559/en
http://www.ni.com/white-paper/13575/en
I hope this help you.
Regards
