Multifunction DAQ
Is there a address offset for a AT-MIO-16L-9 available?
Can i use a AT-MIO-16L-9 with the standart I/O control orders from C++,VB or Basic (inp,outp), can i get a addressoffset in the web ?
many thanks for every answer
Hans
(2,632 Views)
Hans;
I'm assuming that what you are trying is to program the board throug its registries. National Instruments doesn't support that way of programming, however, you can find good references at www.ni.com.
To find the documentation available regarding register level programming, you can type +register +level at the search field of NI home page.
Hope this helps.
Filipe A.
(2,632 Views)
